[Qgis-developer] QT Designer not installed but menu is with Network Installer
C Hamilton
adenaculture at gmail.com
Fri Sep 2 17:13:34 PDT 2016
If you are installing QGIS from scratch using the OSGeo4W Network installer
and using the Advanced install and install qgis:QGIS Desktop. After the
install when it creates the OSGeo4W menu items it lists
Qt Designer with QGIS 2.16.2 custom widgets
However, not all libraries have been installed for it to run. You have to
go back under "Libs" and select "qt4-devel: Qt4 headers and libraries" for
it to work.
Either the menu item should not be included or qt4-devel needs to be
included with the qgis install. I vote for the latter.
You only see this problem if you are starting from scratch and have never
selected qt4-devel to be installed.
Cheers,
Calvin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160902/4b0d35d4/attachment.html>
