[Qgis-developer] QGIS crash removing group containing rasters
Luca Congedo semiautomatic.blogger at gmail.com
Sat Sep 3 02:43:16 PDT 2016
Hello everybody,
removing a group (created by the Semi-Automatic Classification Plugin)
containing rasters from QGIS layers causes a crash.
To reproduce, if you create 2 or more classification previews with the
Semi-Automatic Classification Plugin and then remove the group
'Class_temp_group' from the layers.
Is there anything I can do at the plugin level, or should I open a ticket?
Thank you,
Luca
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160903/c3174b83/attachment.html>
