[Qgis-developer] QGIS crash removing group containing rasters
Matthias Kuhn matthias at opengis.ch
Sat Sep 3 02:53:58 PDT 2016
Hi Luca,
does it also happen when you do the same process manually?
Matthias
On 09/03/2016 11:43 AM, Luca Congedo wrote:
> Hello everybody,
> removing a group (created by the Semi-Automatic Classification Plugin)
> containing rasters from QGIS layers causes a crash.
> To reproduce, if you create 2 or more classification previews with the
> Semi-Automatic Classification Plugin and then remove the group
> 'Class_temp_group' from the layers.
> Is there anything I can do at the plugin level, or should I open a ticket?
> Thank you,
> Luca
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
