[Qgis-developer] QGIS crash removing group containing rasters
Luca Congedo semiautomatic.blogger at gmail.com
Sat Sep 3 02:57:54 PDT 2016
Hi Matthias,
yes, it happens in Windows when removing the group manually (it seems that
Linux is not affected).
I had a button in the plugin for removing the temporary rasters which I
have now disabled in a plugin update.
Luca
2016-09-03 11:53 GMT+02:00 Matthias Kuhn <matthias at opengis.ch>:
> Hi Luca,
> does it also happen when you do the same process manually?
> Matthias
> On 09/03/2016 11:43 AM, Luca Congedo wrote:
> > Hello everybody,
> > removing a group (created by the Semi-Automatic Classification Plugin)
> > containing rasters from QGIS layers causes a crash.
> > To reproduce, if you create 2 or more classification previews with the
> > Semi-Automatic Classification Plugin and then remove the group
> > 'Class_temp_group' from the layers.
> > Is there anything I can do at the plugin level, or should I open a
> ticket?
> > Thank you,
> > Luca
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160903/88e9fc57/attachment.html>
