[Qgis-developer] qgis crash using QThread in a plugin script
Akbar Gumbira
akbargumbira at gmail.com
Mon Sep 5 18:58:33 PDT 2016
It would be more helpful if you point to the code here. I had a problem
with QThread (was initially inheriting QThread) but managed to fix the
problem by creating workers and move the worker object to thread. This is a
good article about multithreading in qgis
https://snorfalorpagus.net/blog/2013/12/07/multithreading-in-qgis-python-plugins/
On Sep 5, 2016 23:01, "Sergio Vignali" <vignalisergio30 at gmail.com> wrote:
> Dear all,
> I wrote a python script that aims to execute neighbourhood statistics in
> raster layer. My script uses QThread to update a QList and a QProgressBar
> and everithing works fine if I run the script from PyCharm, the progressbar
> and the list are updated. The problem appears when I move my script in a
> Qgis plugin, the UI appears correctly but clicking OK the software
> crashes...
> I am using qgis 2.14 in a linux machine, do you have any advice?
> All the best
> Sergio Vignali
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160906/54aee1af/attachment.html>
