[Qgis-developer] pg_services on Windows
Paolo Cavallini
cavallini at faunalia.it
Thu Sep 8 23:09:54 PDT 2016
Il 09/09/2016 08:06, Tudor Barascu ha scritto:
> You can check out 1.3. Setup workstation — QGEP 0.5 documentation
> <https://qgep.github.io/docs/installation-guide/workstation.html?highlight=pg_service>
> for your answer.
> Basically, on Windows, the caveat is that you need to save
> |pg_service.conf| in Unix format in order to work. One way to do it is
> to open it with Notepad++ <https://notepad-plus-plus.org/> and |Edit -->
> EOL Conversion --> UNIX Format --> File save|
As mentioned, I have done and double checked this.
Thanks anyway, Tudor.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
