[Qgis-developer] pg_services on Windows
Neumann, Andreas a.neumann at carto.net
Fri Sep 9 04:42:48 PDT 2016
Hi Paolo,
I was trying to help, but I am running out of ideas. We use pg services
without any issues in our mixed Windows/Linux environments.
Two more ideas:
1. Try if you can connect in the OSGEO4W shell with your service
definition. Make sure that the shell sees your environment variable. You
can connect in the OSGEO shell with:
psql "service=servicename"
If that fails, then it is a general problem in your OS or libpq, and not
the fault of QGIS.
2. Try to put the pg_service.conf file inside the Windows file system,
not through network shares from Linux
Other than that - no idea what could be wrong.
Andreas
On 2016-09-09 08:25, Paolo Cavallini wrote:
> Il 09/09/2016 07:59, Paolo Cavallini ha scritto:
>> Hi all,
>> I'm trying to make PostgreSQL services work on Windows:
>> * I have a valid pg_services.conf, that works on Linux
> sorry, the name of the file is correct: pg_service.conf
>> * I have double checked, and it has UNIX EOL
>> * I have set up both PGSYSCONFDIR and PGSERVICEFILE in various tests in
>> Global options --> System --> User specific environment variables
>> but I always get:
>> definition of service "test" not found
>> (QGIS 2.14.2 on Windows 7).
>> Thanks for any suggestion.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160909/4d64690f/attachment.html>
