[Qgis-developer] pg_services on Windows
Paolo Cavallini
cavallini at faunalia.it
Fri Sep 9 07:13:25 PDT 2016
Hi Andreas,
Il 09/09/2016 13:42, Neumann, Andreas ha scritto:
> 1. Try if you can connect in the OSGEO4W shell with your service
> definition. Make sure that the shell sees your environment variable. You
> can connect in the OSGEO shell with:
> psql "service=servicename"
I was successful with
set PGSERVICEFILE=C:\Users\John\Desktop\pg_service.conf
(with "C:\Users..." it failed).
Subsequent startup of QGIS however hung out, even after rebooting the
machine.
Apparently then there is an issue in defining variables within QGIS,
either not working and/or conflicting with existing ones.
Nice side effect: now QGIS wont' start anymore :(
All the best, and thanks again.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
