[Qgis-developer] qgis crash using QThread in a plugin script
Marco Bernasocchi
marco at opengis.ch
Tue Sep 13 23:18:58 PDT 2016
Hi Segio
On 14.09.2016 07:38, Akbar Gumbira wrote:
> Just read your code again in stackexchange. If you want to have a new
> fresh instance of your dialog every time you open the dialog, you need
> to restructure your code. I think you use Plugin Builder and you
> instantiated the dialog in the __init__ of the main file. You can remove
> the run method and just open the dialog in the action.
Did you try implementin something like the comment I posted in
Stackexchange?
ciao
Marco Bernasocchi
OPENGIS.ch - berna.io - 27summits.ch
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160914/1eb6b6ed/attachment.sig>
