[Qgis-developer] 2.16 Globe plugin on Mac
Daven Quinn dev at davenquinn.com
Tue Sep 20 22:49:02 PDT 2016
Hello,
I just completed a source installation of QGIS 2.16.2 on Mac, using a modified version of the Homebrew osgeo4mac/qgis–214 formula. I was particularly excited to try out the new globe plugin. QGIS builds correctly and is usable, but the globe plugin appears to be totally disabled, and doesn’t show up in the plugin directory or menu.
I built the formula with globe enabled (the Homebrew —with-globe option translates to —DWITH_GLOBE=TRUE —DOSG_PLUGIN_PATH=/usr/local/lib/osgPlugins-3.4 compile options. I’m running osg 3.4 and osgearth 2.7. Both of these are built using homebrew formula, with qt support, and I think they are within the range of supported dependencies for the globe plugin.
In the “advanced” settings menu, there is a section for globe plugin settings, but I cannot see any other feedback that the plugin is installed.
Any insights on what might be disabling the globe plugin, and how I could compile QGIS in order to include this? I’ve successfully used my install of osgearth to view GIS data described by raw *.earth files, so I think it’s unlikely to be a dependency issue.
Thanks, Daven
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160920/633ec0da/attachment.html>
