[Qgis-developer] 2.16 Globe plugin on Mac
Sandro Mani manisandro at gmail.com
Wed Sep 21 07:30:33 PDT 2016
Is the library being built? I.e. under Linux it is
lib/qgis/plugins/libglobeplugin.so
If yes, look at the debug output of qgis when starting and you should be
able to see some info about why the plugin is being rejected.
Sandro
On 21.09.2016 16:28, Daven Quinn wrote:
> Hi Sandro,
> It is not listed anywhere in the plugin manager to be enabled or
> disabled. All other plugins I am accustomed to seeing in that list are
> there (629 in total) but “Globe” is nowhere to be found, unless it
> resides under some non-intuitive name. So, no opportunity to enable
> the plugin in the usual way.
> Thanks,
> Daven
> On September 21, 2016 at 1:16:54 AM, Sandro Mani (manisandro at gmail.com
> <mailto:manisandro at gmail.com>) wrote:
>> Hi Daven
>> > doesn’t show up in the plugin directory or menu
>> Does this mean in the plugins menu or in the list of plugins in the
>> plugin manager? If the former, please check the plugin manager an
>> make sure the plugin is enabled. With the plugin enabled, a globe
>> icon should also appear in the plugin toolbar.
>> Hope this helps
>> Sandro
>> On 21.09.2016 07:49, Daven Quinn wrote:
>>> Hello,
>>> I just completed a source installation of QGIS 2.16.2 on Mac, using
>>> a modified version of the Homebrew osgeo4mac/qgis–214 formula. I was
>>> particularly excited to try out the new globe plugin. QGIS builds
>>> correctly and is usable, but the globe plugin appears to be totally
>>> disabled, and doesn’t show up in the plugin directory or menu.
>>> I built the formula with globe enabled (the Homebrew |—with-globe|
>>> option translates to |—DWITH_GLOBE=TRUE
>>> —DOSG_PLUGIN_PATH=/usr/local/lib/osgPlugins-3.4| compile options.
>>> I’m running osg 3.4 and osgearth 2.7. Both of these are built using
>>> homebrew formula, with qt support, and I think they are within the
>>> range of supported dependencies for the globe plugin.
>>> In the “advanced” settings menu, there is a section for globe plugin
>>> settings, but I cannot see any other feedback that the plugin is
>>> installed.
>>> Any insights on what might be disabling the globe plugin, and how I
>>> could compile QGIS in order to include this? I’ve successfully used
>>> my install of osgearth to view GIS data described by raw |*.earth|
>>> files, so I think it’s unlikely to be a dependency issue.
>>> Thanks, Daven
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> List info:http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe:http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160921/d7d803e4/attachment.html>
