[Qgis-developer] 2.16 Globe plugin on Mac
Daven Quinn dev at davenquinn.com
Wed Sep 21 07:28:18 PDT 2016
Hi Sandro,
It is not listed anywhere in the plugin manager to be enabled or disabled. All other plugins I am accustomed to seeing in that list are there (629 in total) but “Globe” is nowhere to be found, unless it resides under some non-intuitive name. So, no opportunity to enable the plugin in the usual way.
Thanks,
Daven
On September 21, 2016 at 1:16:54 AM, Sandro Mani (manisandro at gmail.com) wrote:
Hi Daven
> doesn’t show up in the plugin directory or menu
Does this mean in the plugins menu or in the list of plugins in the plugin manager? If the former, please check the plugin manager an make sure the plugin is enabled. With the plugin enabled, a globe icon should also appear in the plugin toolbar.
Hope this helps
Sandro
On 21.09.2016 07:49, Daven Quinn wrote:
Hello,
I just completed a source installation of QGIS 2.16.2 on Mac, using a modified version of the Homebrew osgeo4mac/qgis–214 formula. I was particularly excited to try out the new globe plugin. QGIS builds correctly and is usable, but the globe plugin appears to be totally disabled, and doesn’t show up in the plugin directory or menu.
I built the formula with globe enabled (the Homebrew —with-globe option translates to —DWITH_GLOBE=TRUE —DOSG_PLUGIN_PATH=/usr/local/lib/osgPlugins-3.4 compile options. I’m running osg 3.4 and osgearth 2.7. Both of these are built using homebrew formula, with qt support, and I think they are within the range of supported dependencies for the globe plugin.
In the “advanced” settings menu, there is a section for globe plugin settings, but I cannot see any other feedback that the plugin is installed.
Any insights on what might be disabling the globe plugin, and how I could compile QGIS in order to include this? I’ve successfully used my install of osgearth to view GIS data described by raw *.earth files, so I think it’s unlikely to be a dependency issue.
Thanks, Daven
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160921/0c28b748/attachment-0001.html>
