[Qgis-developer] 2.16 Globe plugin on Mac
Sandro Mani manisandro at gmail.com
Wed Sep 21 01:16:49 PDT 2016
Hi Daven
 > doesn’t show up in the plugin directory or menu
Does this mean in the plugins menu or in the list of plugins in the
plugin manager? If the former, please check the plugin manager an make
sure the plugin is enabled. With the plugin enabled, a globe icon should
also appear in the plugin toolbar.
Hope this helps
Sandro
On 21.09.2016 07:49, Daven Quinn wrote:
> Hello,
> I just completed a source installation of QGIS 2.16.2 on Mac, using a
> modified version of the Homebrew osgeo4mac/qgis–214 formula. I was
> particularly excited to try out the new globe plugin. QGIS builds
> correctly and is usable, but the globe plugin appears to be totally
> disabled, and doesn’t show up in the plugin directory or menu.
> I built the formula with globe enabled (the Homebrew |—with-globe|
> option translates to |—DWITH_GLOBE=TRUE
> —DOSG_PLUGIN_PATH=/usr/local/lib/osgPlugins-3.4| compile options. I’m
> running osg 3.4 and osgearth 2.7. Both of these are built using
> homebrew formula, with qt support, and I think they are within the
> range of supported dependencies for the globe plugin.
> In the “advanced” settings menu, there is a section for globe plugin
> settings, but I cannot see any other feedback that the plugin is
> installed.
> Any insights on what might be disabling the globe plugin, and how I
> could compile QGIS in order to include this? I’ve successfully used my
> install of osgearth to view GIS data described by raw |*.earth| files,
> so I think it’s unlikely to be a dependency issue.
> Thanks, Daven
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160921/8fa6f5ac/attachment.html>
