[Qgis-developer] Expression: does an escape char is defined for LIKE expression
Nathan Woodrow
madmanwoo at gmail.com
Fri Sep 23 20:27:45 PDT 2016
Hey,
When would you normally need an escape char for LIKE?
- Nathan
On Fri, Sep 23, 2016 at 6:33 PM, René-Luc Dhont <rldhont at gmail.com> wrote:
> Hi Devs,
> I'd like to know if an escape character is defined for the LIKE operator
> in QGIS Expression.
> If I take a look at the code src/core/qgsexpression.cpp:4343 no escape
> char is used
> if ( mOp == boLike || mOp == boILike || mOp == boNotLike || mOp ==
> boNotILike ) // change from LIKE syntax to regexp
> QString esc_regexp = QRegExp::escape( regexp );
> // XXX escape % and _ ???
> esc_regexp.replace( '%', ".*" );
> esc_regexp.replace( '_', '.' );
> matches = QRegExp( esc_regexp, mOp == boLike || mOp == boNotLike
> ? Qt::CaseSensitive : Qt::CaseInsensitive ).exactMatch( str );
> Do you think we have to add one ?
> Regards,
> René-Luc
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160924/3234fad0/attachment.html>
