Hi Nathan,
I'd like to escape _ or %.
I'd like to do it because I've been requested to fix the OGC Element
PropertyIsLike.
This element can specify it's own escape char, single char and wild char
For exemple the * can be defined as the wild char so the % has to be
escaped to be used as an expression.
I'm preparing a PR with updated help.
René-Luc
Le 24/09/2016 à 05:27, Nathan Woodrow a écrit :
> Hey,
> When would you normally need an escape char for LIKE?
> - Nathan
> On Fri, Sep 23, 2016 at 6:33 PM, René-Luc Dhont <rldhont at gmail.com
> <mailto:rldhont at gmail.com>> wrote:
> Hi Devs,
> I'd like to know if an escape character is defined for the LIKE
> operator in QGIS Expression.
> If I take a look at the code src/core/qgsexpression.cpp:4343 no
> escape char is used
> if ( mOp == boLike || mOp == boILike || mOp == boNotLike
> || mOp == boNotILike ) // change from LIKE syntax to regexp
> QString esc_regexp = QRegExp::escape( regexp );
> // XXX escape % and _ ???
> esc_regexp.replace( '%', ".*" );
> esc_regexp.replace( '_', '.' );
> matches = QRegExp( esc_regexp, mOp == boLike || mOp ==
> boNotLike ? Qt::CaseSensitive : Qt::CaseInsensitive ).exactMatch(
> str );
> Do you think we have to add one ?
> Regards,
> René-Luc
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe:
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160926/b31a5c5d/attachment.html>
