[Qgis-developer] qgis kartoza docker images, use configpath option?
Luigi Pirelli luipir at gmail.com
Tue Sep 27 01:24:29 PDT 2016
correct... but IMHO would be better more flexible in the sense of
check the existence of the env var in startup.sh and set the value of
trhe env var just as -e parameter in the docker run => in this way you
can have different container (desktop) on different configurations.
You have to build your image if you want the container container your
modifications (well there could be other dynamic solutions... but more
complex for who starts with docker)
but you just have to follow the build guide by tim  that is very
simple https://github.com/kartoza/docker-qgis-desktop/tree/develop/2.14.
cheers
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 26 September 2016 at 16:12, Régis Haubourg <regis.haubourg at gmail.com> wrote:
> Thanks Luigi,
> I'm quite new to docker, if I get it right, I should:
> 1 - Add a new environment variable to docker file. something like  "ENV QGIS_PROFILE /project/.qgis2"
> 2 - Change startup.sh from su $USER_NAME -c "/usr/bin/qgis" to "su $USER_NAME -c "/usr/bin/qgis --confipath QGIS_PROFILE"
> 3 - Build my own docker image
> 4 - if that works, submit a PR :)
> I had the hope of not having to build my own images (too much to learn at once).  I guess I should startup .sh should test if
> QGIS_PROFILE exists or not and add --confipath argument only if true.
> Do I miss something?
> Régis
> Le lundi 26 septembre 2016 à 15:46 +0200, Luigi Pirelli a écrit :
>> http://stackoverflow.com/questions/19537645/get-environment-variable-value-in-dockerfile
>> then set env that will be used in the start.sh
>> I did the base of 2.14 dockerfile... but I didn't follow it's
>> evolution... probably there is an issue.
>> better than a issue, would be fine a PR :) edit Dockerfile is a really
>> simple beast ;)
>> cheers
>> Luigi Pirelli
>> * Mastering QGIS:
>> On 26 September 2016 at 14:16, Régis Haubourg <regis.haubourg at gmail.com> wrote:
>> > Hi there,
>> > I'm trying to set up multiple docker images to test different environments
>> > in ubuntu xenial.
>> > I just gave a try to excellent Tim's repository with  docker images for all
>> > QGIS versions.
>> > My question : Is it possible to launch a docker image with --configpath
>> > option as an argument so that I can use differents qgis profiles with one
>> > image?  If yes, how can I achieve that?
>> > Thanks for your lights.
>> > BTW, I could run QGIS master but 2.14.6 returns that error:
>> > docker: Error response from daemon: oci runtime error: exec: "/start.sh":
>> > stat /start.sh: no such file or directory.
>> > Shall I create an issue in kartoza repo?
>> > Régis Haubourg
>> > Attention, changement d'adresse mail!
>> > Mon adresse principale devient désormais regis.haubourg at gmail.com
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
