[Qgis-developer] Testing plugins against QGIS3 with Travis
Matthias Kuhn
matthias at opengis.ch
Tue Sep 27 04:04:34 PDT 2016
On 09/27/2016 12:46 PM, Sandro Santilli wrote:
> On Tue, Sep 27, 2016 at 12:23:39PM +0200, Matthias Kuhn wrote:
>> On 09/27/2016 11:49 AM, Sandro Santilli wrote:
>>> On Tue, Sep 27, 2016 at 11:25:00AM +0200, Alessandro Pasotti wrote:
>>>> QGIS is already built into the docker images and you don't need to buld it
>>>> in a travis job (it would take too long) but yes, the docker pull operation
>>>> could take a while.
>>> Do Travis agent not cache downloaded docker images ?
>> The strategy which we use for QGIS tests (and plugin tests) and some
>> other plugins which I've been involved with do not depend on Docker but
>> instead on a precise or trusty system where additional dependencies can
>> be installed from repositories (which are currently missing for almost?
>> all distributions).
> Yes, but Alessandro was suggesting a user to use a docker-based travis
> to test plugins, if I'm not mistaken.
Ah yes, correct
> It could actually also be a good idea to use docker for QGIS, as it
> would possibly reduce testing time (a qgis-build-test docker could be
> provided with all pre-built dependencies).
It shouldn't make a big difference. Installing deps from a (cached) apt
repository or setting up a (cached) docker instance should be comparable
from what I can see?
Most of the time is spent on building QGIS where a major improvement
could be achieved by having a persistent ccache directory. This has cut
down build time from ~50 minutes to 10-20 minutes (unless some very low
level files change).
Matthias
> We're doing this on Drone for postgis, using ad-hoc docker images, see
> https://git.osgeo.org/gogs/postgis/postgis-docker/src/master/build-test
> Drone agents cache the image, so all they have to do is fetching the
> PostGIS code and build/check that.
> --strk;
