[Qgis-developer] Test crashes on if providers not found.
David Marteau dmarteau at 3liz.com
Tue Sep 27 06:07:56 PDT 2016
I'm trying to run tests on OSX 10.9.5 (Maverick), by running the following
> sudo make install
> make test
I have the following warning "!!! prefix path was requested, but it is not valid - we do not run from installed path !!!" then all tests
involving loading a provider are crashing.
I figured out that provider was not found  and In those tests will crash with a segfault because they are trying to dereference a null pointer on provider before testing if the returned objects are valid or not.
Is there something missing for setting the correct prefix in tests ?
Thx
David
