[Qgis-developer] QGIS 2.16.3 Invert for Singleband pseudocolor still not working
Mathieu Pellerin nirvn.asia at gmail.com
Tue Sep 27 23:48:16 PDT 2016
There's an open PR that handles this issue here
https://github.com/qgis/QGIS/pull/3271
On Sep 28, 2016 13:46, "Richard Duivenvoorde" <rdmailings at duif.net> wrote:
> On 27-09-16 22:41, C Hamilton wrote:
> > Several individuals have mentioned the problem with the Invert not
> > working in 2.16.2 when styling a gray scale image with Singleband
> > pseudocolor as the render type. I thought it would be fixed in this
> > release, but it wasn't so I want to bring it up again as this is a
> > problem for me.
> > It works if the Mode is set to "Equal interval" or "Quantile" but it
> > does not work with "Continuous." It works properly in QGIS 2.14.
> Hi Chris,
> sorry cannot help you, but it helps if you point to a relevant issue, or
> in case there is not one, create a good issue: that is: provide a small
> dataset, and maybe a picture with a desired img and one which is NOT
> good. That gives devs a good starting point, AND shows that somebody is
> at least interested enough to create a good issue report :-)
> Regards,
> Richard
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160928/204148db/attachment.html>
