[Qgis-developer] QGIS 2.16.3 Invert for Singleband pseudocolor still not working
Richard Duivenvoorde
rdmailings at duif.net
Tue Sep 27 23:45:51 PDT 2016
On 27-09-16 22:41, C Hamilton wrote:
> Several individuals have mentioned the problem with the Invert not
> working in 2.16.2 when styling a gray scale image with Singleband
> pseudocolor as the render type. I thought it would be fixed in this
> release, but it wasn't so I want to bring it up again as this is a
> problem for me.
> It works if the Mode is set to "Equal interval" or "Quantile" but it
> does not work with "Continuous." It works properly in QGIS 2.14.
Hi Chris,
sorry cannot help you, but it helps if you point to a relevant issue, or
in case there is not one, create a good issue: that is: provide a small
dataset, and maybe a picture with a desired img and one which is NOT
good. That gives devs a good starting point, AND shows that somebody is
at least interested enough to create a good issue report :-)
Regards,
Richard
