[Qgis-developer] QGIS Server 3.0 roadmap
René-Luc Dhont rldhont at gmail.com
Wed Sep 28 06:12:52 PDT 2016
Hi Nyall,
I like your proposition on QGIS Project and Layer Registry. Will you
write a QEP about it ? Do you wait the grant vote ?
About the server part, we used QgsMapLayerRegistry because some widgets
rely on map layer ids and not map layer pointers. We create our own
Project parser because the QgsProject load segfault if the
QgsApplication is instanciate without interface (GUIenabled to false).
And QgsProject is too close to QGIS gui.
René-Luc
Le 27/09/2016 à 09:19, Nyall Dawson a écrit :
> I'd really appreciate it if someone more familiar with the server
> architecture could summarise what's missing in core's project/layer
> handling. I may be missing something, but would a something like this
> help?:
> - add a QgsProjectRegistry, with an instance attached to
> QgsApplication. Change all the use of QgsProject::instance to
> QgsProjectRegistry::currentProject().
> - move QgsMapLayerRegistry from an instance to a member within
> QgsProject. Core code would then use
> currentProject()->mapLayerRegistry() instead of
> QgsMapLayerRegistry::instance()
> - server could directly pull projects from the registry (via some form
> of generated project id) as required and access their map layer
> registries directly
> Nyall
