[Qgis-developer] QGIS D3 DataVis Plugin Status Report
C Hamilton
adenaculture at gmail.com
Fri Sep 30 11:58:51 PDT 2016
Matteo,
I was able to sort of get it running. It does not appear to be able to
display in the QGIS window. I am not sure if it was suppose to or not, but
I saw where it was saving the temporary file and was able to view it in a
web browser. I had to make some small changes to the one .ui file to make
it come up and I see in some of the python modules (not sure they are
actually used) referencing some .ui files that are not there. Do you have a
functioning DataPlot that you could zip up and send to me?
My main concern is it is dependent upon a python library that is not a part
of the QGIS distribution. I can't have users install plotly in order to get
the plugin to work. I don't know plotly, but can it be in a folder within
the plugin directory and executed from there or does it have to be
installed into the python distribution.
Thanks!!!
On Fri, Sep 30, 2016 at 11:15 AM, matteo <matteo.ghetta at gmail.com> wrote:
> Hi Hamilton,
> a few months ago, during the QGIS Hackfest in Girona, me and Michael
> Douchin of LizMap started a D3 plugin based on the plotly library.
> unfortunately we did not have to much time to continue the work, but it
> is still here
> https://github.com/ghtmtt/DataPlot
> if you want to give it a try, you just have to install the plotly
> library with pip and clone the repo in the plugin folder
> fell free to make any suggestion!
> Cheers
> Matteo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160930/419dd392/attachment.html>
