[Qgis-developer] QGIS D3 DataVis Plugin Status Report
Matteo Ghetta matteo.ghetta at gmail.com
Fri Sep 30 15:04:17 PDT 2016
Hi Calvin,
well thanks to the complete refactoring code made by Micheal and Etienne
the ui is completely changed.
Just clone the last version of the repository and try it.
No more external tmp file. The plots are directly shown inside a webview.
Moreover the plot is interactive with the map cavas objects.
Give it a try! Adding other plot types is realy easy too.
If we can put the efforts togheter it will be awesome.
Cheers
Matteo
Il 30/set/2016 20:58 "C Hamilton" <adenaculture at gmail.com> ha scritto:
> Matteo,
> I was able to sort of get it running. It does not appear to be able to
> display in the QGIS window. I am not sure if it was suppose to or not, but
> I saw where it was saving the temporary file and was able to view it in a
> web browser. I had to make some small changes to the one .ui file to make
> it come up and I see in some of the python modules (not sure they are
> actually used) referencing some .ui files that are not there. Do you have a
> functioning DataPlot that you could zip up and send to me?
> My main concern is it is dependent upon a python library that is not a
> part of the QGIS distribution. I can't have users install plotly in order
> to get the plugin to work. I don't know plotly, but can it be in a folder
> within the plugin directory and executed from there or does it have to be
> installed into the python distribution.
> Thanks!!!
> On Fri, Sep 30, 2016 at 11:15 AM, matteo <matteo.ghetta at gmail.com> wrote:
>> Hi Hamilton,
>> a few months ago, during the QGIS Hackfest in Girona, me and Michael
>> Douchin of LizMap started a D3 plugin based on the plotly library.
>> unfortunately we did not have to much time to continue the work, but it
>> is still here
>> https://github.com/ghtmtt/DataPlot
>> if you want to give it a try, you just have to install the plotly
>> library with pip and clone the repo in the plugin folder
>> fell free to make any suggestion!
>> Cheers
>> Matteo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161001/6470ca8b/attachment.html>
