[Qgis-developer] QGIS D3 DataVis Plugin Status Report
Thomas Gratier
osgeo.mailinglist at gmail.com
Fri Sep 30 16:27:15 PDT 2016
Did you ever try Vega https://vega.github.io/vega/? As stated, "With Vega,
you can describe the visual appearance and interactive behavior of a
visualization in a JSON format, and generate views using HTML5 Canvas or
SVG."
You can see a sandbox to try it
http://vega.github.io/vega-editor/?mode=vega&spec=bar
It uses D3. With this approach, less need to code, more need to
configure/create a configuration.
FYI, ESRI company has a product based on it called Cedar
http://esri.github.io/cedar/ for creating online charts with their online
maps
Cheers
Thomas Gratier
2016-10-01 0:04 GMT+02:00 Matteo Ghetta <matteo.ghetta at gmail.com>:
> Hi Calvin,
> well thanks to the complete refactoring code made by Micheal and Etienne
> the ui is completely changed.
> Just clone the last version of the repository and try it.
> No more external tmp file. The plots are directly shown inside a webview.
> Moreover the plot is interactive with the map cavas objects.
> Give it a try! Adding other plot types is realy easy too.
> If we can put the efforts togheter it will be awesome.
> Cheers
> Matteo
> Il 30/set/2016 20:58 "C Hamilton" <adenaculture at gmail.com> ha scritto:
>> Matteo,
>> I was able to sort of get it running. It does not appear to be able to
>> display in the QGIS window. I am not sure if it was suppose to or not, but
>> I saw where it was saving the temporary file and was able to view it in a
>> web browser. I had to make some small changes to the one .ui file to make
>> it come up and I see in some of the python modules (not sure they are
>> actually used) referencing some .ui files that are not there. Do you have a
>> functioning DataPlot that you could zip up and send to me?
>> My main concern is it is dependent upon a python library that is not a
>> part of the QGIS distribution. I can't have users install plotly in order
>> to get the plugin to work. I don't know plotly, but can it be in a folder
>> within the plugin directory and executed from there or does it have to be
>> installed into the python distribution.
>> Thanks!!!
>> On Fri, Sep 30, 2016 at 11:15 AM, matteo <matteo.ghetta at gmail.com> wrote:
>>> Hi Hamilton,
>>> a few months ago, during the QGIS Hackfest in Girona, me and Michael
>>> Douchin of LizMap started a D3 plugin based on the plotly library.
>>> unfortunately we did not have to much time to continue the work, but it
>>> is still here
>>> https://github.com/ghtmtt/DataPlot
>>> if you want to give it a try, you just have to install the plotly
>>> library with pip and clone the repo in the plugin folder
>>> fell free to make any suggestion!
>>> Cheers
>>> Matteo
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161001/5f59c382/attachment-0001.html>
