[Qgis-developer] Plans for next QGIS releases
Jürgen E. Fischer
jef at norbit.de
Sat Apr 1 02:11:43 PDT 2017
Hi Harrissou,
On Fri, 31. Mar 2017 at 21:53:33 +0200, DelazJ wrote:
> #. 3.0 will be a LTR (actually from 3.0.9 - nine months after first
> release?)
No, 3.2.0 will be the LTR.
> #. 3.0 will be LTR for *4 months*, replaced by 3.2
There's a four month overlap where a LTR is also the current LR. For that time
it doesn't replace the old release in the LTR repositories.
3.0 in the LTR column is indeed wrong - that should have been more 2.18 point
releases - fixed.
I also switched the LTR and LR columns as the event refers primarily to the LR
column (maybe a source of confusion).
> - I fail to understand the reason why once 3.0 is released, we continue to
> break our "four-months release" policy.
That's what we discussed - more time to stablize 3.x before it goes LTR.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170401/6c1f8ded/attachment.sig>
