[Qgis-developer] Plans for next QGIS releases
Idan Miara
idan at miara.com
Sun Apr 2 03:55:08 PDT 2017
Shouldn't it say PR in the following line?
LTR 2.18.7 2.14.15 19.05.2017 20 4
On 1 April 2017 at 12:11, Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Harrissou,
> On Fri, 31. Mar 2017 at 21:53:33 +0200, DelazJ wrote:
> > #. 3.0 will be a LTR (actually from 3.0.9 - nine months after first
> > release?)
> No, 3.2.0 will be the LTR.
> > #. 3.0 will be LTR for *4 months*, replaced by 3.2
> There's a four month overlap where a LTR is also the current LR. For that
> time
> it doesn't replace the old release in the LTR repositories.
> 3.0 in the LTR column is indeed wrong - that should have been more 2.18
> point
> releases - fixed.
> I also switched the LTR and LR columns as the event refers primarily to
> the LR
> column (maybe a source of confusion).
> > - I fail to understand the reason why once 3.0 is released, we continue
> to
> > break our "four-months release" policy.
> That's what we discussed - more time to stablize 3.x before it goes LTR.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel.
> +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
> +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on FreeNode
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170402/339e43e9/attachment.html>
