[Qgis-developer] PostGIS Rasters
Neumann, Andreas
a.neumann at carto.net
Mon Apr 10 22:56:44 PDT 2017
If there will be a new Postgis raster provider for QGIS, it should also
support the pyramid tables (separate tables) - which as far as I know -
is not yet supported. If you add a layer from DB-manager you load a
fixed resolution and the other pyramid tables won't be used. Thats one
of the reasons, rasters in Postgis display quite slow in QGIS.
Andreas
On 2017-04-11 04:16, Robert Hewlett wrote:
> Hi,
> Are there plans to build a plugin for PostGIS rasters similar to the vector plugin. I know how to add the rasters from the DB manager but the experience/workflow is much different and the connections go 'stale'.
> I am willing to help code it.
> Regards,
> Rob
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170411/36d4c84d/attachment.html>
