[Qgis-developer] Set processing input default value to layer custom property
Ari Jolma ari.jolma at gmail.com
Tue Apr 11 00:09:43 PDT 2017
I have a small processing model where one of the algorithms is Rasterize
from GDAL. I needed to set the target resolution to be the same as the
one in one of the input rasters to the model.
The problem was thus the same as yours. My solution was to write a very
simple processor, which takes raster as input and outputs its
resolution. I could then hook its input to the raster in the model input
and hook its output to the resolution input of the rasterize algorithm.
My answer is thus that you need to make a model and find or make an
algorithm, which outputs the layer property you need.
Cheers,
Ari
08.04.2017, 16:33, Tom Chadwin kirjoitti:
> I have two inputs to a processing algorithm, one layer, one string. Is it
> possible to set the default value of the string input to the value of a
> given custom property of the layer selected for the other input?
> Thanks
> Tom
> Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Set-processing-input-default-value-to-layer-custom-property-tp5316416.html
> Sent from the QGIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
