[Qgis-developer] Are there plans to create a unique "Add layer" tool?
Alexandre Neto
senhor.neto at gmail.com
Thu Apr 20 01:47:46 PDT 2017
Fine with me.
Stéphane Henriod <stephanebek at gmail.com> escreveu no dia terça, 18/04/2017
às 05:46:
> Hi all
> Harrissou has quite intensively re-organised the doc, which is now, IMO,
> much clearer. Thanks for that!
> But lots of changes are in "suggestion mode". I'd like to accept all those
> changes to increase the clarity and readability. Any objection on this?
> Thanks and cheers
> Stéphane
> Le mercredi 12 avril 2017, Alexandre Neto <senhor.neto at gmail.com> a
> écrit :
>> Hi Stéphane,
>> I believe it's a great starting point, very complete (I would not
>> remember/consider some types of data).
>> We still need to fill the second page and discuss the possible UI/UX
>> implementation. Then, we will need some developers (I'm not a developer) to
>> consider the requests and filter what would be hard or impossible to tackle.
>> Our best chance to have this implemented is by doing baby steps. I would
>> not consider more data format/providers than the ones we have in the manage
>> layers toolbar in this first phase.
>> Thanks!
>> 11/04/2017 às 12:57:
>>> Hi Alexandre
>>> this is indeed great!
>>> Is the gdoc as it is now helpful enough for you to design a possible
>>> implementation? Or, if not, what other inputs / comments would be necessary?
>>> Cheers
>>> Stéphane
>>> Le lundi 10 avril 2017, Alexandre Neto <senhor.neto at gmail.com> a écrit :
>>>> Hello all,
>>>> At Boundless we are planning to put some development time in this
>>>> "unified add layer" button/feature. As others already did, our idea was to
>>>> use the browser panel as a base for replacing most of the buttons and add
>>>> any capabilities that are still missing.
>>>> So, let's work together to find what are those missing pieces, and how
>>>> it would be the best way to implement it. We will put our thoughts in the
>>>> Google document. As soon we have it stabilized we can start creating a QEP
>>>> for it.
>>>> Thanks,
>>>> Alexandre Neto
>>>> Stéphane Henriod <stephanebek at gmail.com> escreveu no dia quinta,
>>>> 6/04/2017 às 12:14:
>>>>> Thanks Harrissou!
>>>>> I took the liberty to remove the first table (that I created) and to
>>>>> leave only yours. It is more complete anyway
>>>>> Cheers
>>>>> Stéphane
>>>>> Le mercredi 5 avril 2017, DelazJ <delazj at gmail.com> a écrit :
>>>>>> I took the liberty to do some changes to the doc (especially add a
>>>>>> new table with more detailed features on the existing tools + comments).
>>>>>> It's supposed to replace the table already drafted but I didn't go so far
>>>>>> without a review.
>>>>>> 2017-04-05 10:36 GMT+02:00 DelazJ <delazj at gmail.com>:
>>>>>>> Hi Stéphane,
>>>>>>> actually there's no more UX team (list). UX mailing list has been
>>>>>>> shut down months ago because it used to refer to dev list for most of
>>>>>>> decisions/advices so UX matters are now discussed either in the dev mailing
>>>>>>> list (we maybe can keep this thread) or, I guess until QGIS3 release, in
>>>>>>> the qgis3_UIX_discussion repository.
>>>>>>> Regards,
>>>>>>> Harrissou
>>>>>>> 2017-04-05 10:19 GMT+02:00 Stéphane Henriod <stephanebek at gmail.com>:
>>>>>>>> Hi all
>>>>>>>> there have been a few additions in the Gdoc already (not sure from
>>>>>>>> whom) but I don't know if this is already sufficient for developers to take
>>>>>>>> this up?
>>>>>>>> Also, I am not sure how to reach out to the UX team. Through a
>>>>>>>> separate mailing list? Or is it sufficient to have it here
>>>>>>>> https://github.com/qgis/qgis3_UIX_discussion/issues/1 ?
>>>>>>>> Cheer
>>>>>>>> Stéphane
>>>>>>>> Le mardi 4 avril 2017, Stéphane Henriod <stephanebek at gmail.com> a
>>>>>>>> écrit :
>>>>>>>>> Thanks Nyall!
>>>>>>>>> Here I just created a Gdoc to collect info mentioned in your
>>>>>>>>> points 1-4 + a:
>>>>>>>>> https://docs.google.com/document/d/1aMX9jOfl10q8oETRzOHSHnRpHCc7UJ1dDnCCq3VyTAY/edit?usp=sharing
>>>>>>>>> All interested, feel free to contribute, I might not have the full
>>>>>>>>> overview
>>>>>>>>> Thanks and cheers
>>>>>>>>> Stéphane
>>>>>>>>> “When you travel, remember that a foreign country is not designed
>>>>>>>>> to make you comfortable. It is designed to make its own people
>>>>>>>>> comfortable." -- Clifton Fadiman
>>>>>>>>> 2017-04-04 13:53 GMT+06:00 Nyall Dawson <nyall.dawson at gmail.com>:
>>>>>>>>>> On 4 April 2017 at 17:46, Stéphane Henriod <stephanebek at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>> > Thanks a lot Anita for the info!
>>>>>>>>>> > I re-located the issue: http://hub.qgis.org/issues/9451
>>>>>>>>>> > Not sure though if this will make it alive again. Let's see if
>>>>>>>>>> this seems to
>>>>>>>>>> > be a priority for enough users...
>>>>>>>>>> I'd say a good plan to move this forward would be to:
>>>>>>>>>> 1. conduct a thorough survey of what's available via the
>>>>>>>>>> individual
>>>>>>>>>> add vector layer dialogs vs what's currently available in the
>>>>>>>>>> browser
>>>>>>>>>> 2. rank each of the missing settings vs whether or not they are
>>>>>>>>>> still required
>>>>>>>>>> 3. file issues for these missing settings
>>>>>>>>>> 4. ...and get these fixed/implemented
>>>>>>>>>> a. While this is underway I'd also suggest the UX team could test
>>>>>>>>>> and
>>>>>>>>>> evaluate Anita's plugin to identify whether the browser alone is a
>>>>>>>>>> sufficient replacement or whether some tweaks would be required to
>>>>>>>>>> make it a suitable replacement without any loss of "user
>>>>>>>>>> friendliness"
>>>>>>>>>> 1,2,3 and (a) don't require any development experience, so would
>>>>>>>>>> be a
>>>>>>>>>> great project for any interested user to undertake. I suspect 4
>>>>>>>>>> wouldn't be much work for a developer either after all this
>>>>>>>>>> groundwork
>>>>>>>>>> is done.
>>>>>>>>>> Nyall
>>>>>>>> _______________________________________________
>>>>>>>> Qgis-developer mailing list
>>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>>>> Unsubscribe:
>>>>> “When you travel, remember that a foreign country is not designed to
>>>>> make you comfortable. It is designed to make its own people comfortable."
>>>>> -- Clifton Fadiman
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Alexandre Neto
>>>> @AlexNetoGeo
>>>> http://sigsemgrilhetas.wordpress.com
>>>> http://gisunchained.wordpress.com
>>> -- Clifton Fadiman
>> Alexandre Neto
>> @AlexNetoGeo
> “When you travel, remember that a foreign country is not designed to make
> you comfortable. It is designed to make its own people comfortable." --
> Clifton Fadiman
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170420/7ae7ea8b/attachment-0001.html>
