[Qgis-developer] release file after processing.runalg
enrico chiaradia enrico.chiaradia at yahoo.it
Thu Apr 27 07:29:31 PDT 2017
Hi Stefan and many thanks for your answer! but it seems not working :(
Here the new code. I replaced "tempOutput" with "output". Layer is
correctly loaded and removed but "tempOutput" cannot be deleted.
import processing
import os
tempOutput = 'D:/test_alg/map_to_clip.tif'
maskFN = 'D:/test_alg/mask.shp'
output = 'D:/test_alg/clipped_map.tif'
algRes = processing.runalg("gdalogr:cliprasterbymasklayer",
                                         tempOutput,
                                         maskFN,
"-9999",False,False,False,5,4,75,6,1,False,0,False,"",
                                         output)
try:
     # add to the map
     tempLay = QgsRasterLayer(output, "tempLay")
     if not tempLay.isValid(): raise Exception("Failed to load tempLay")
     QgsMapLayerRegistry.instance().addMapLayer(tempLay) #!!!!
     layermap = QgsMapLayerRegistry.instance().mapLayers()
     for i, layer in layermap.iteritems():
       if layer.source() == output:
         print 'layername',layer.source()
         # Remove layer references
         QgsMapLayerRegistry.instance().removeMapLayer(layer.id()) #!!!!
     # Delete the file
     os.remove(tempOutput)
except Exception as e:
     print e
Il 27/04/2017 16:07, Stefan Kiefer ha scritto:
> Hi enrico,
> as far as I see from the reference you added the solution would be to add the result (resp. output) to a Layer instead "tempOutput". Then you remove that Layer, I suppose while removing the layer a reference on "tempOutput" ist released.
> cheers
> Stefan
>> enrico chiaradia <enrico.chiaradia at yahoo.it> hat am 27. April 2017 um 15:13 geschrieben:
>> Dear List,
>> I'd like to remove an existing file (see [tempOutput]) after it was used
>> by a geoalgorithm. The geoalgorithm works perfectly but after its
>> execution, the file [tempOutput] is locked.
>> Here a simple test script that returns "[Error 32] The process cannot
>> access the file because it is being used by another process:
>> 'D:/test_alg/map_to_clip.tif'":
>> import processing
>> import os
>>                                           tempOutput,
>>                                           maskFN,
>>                                           output)
>> try:
>>       print e
>> I also found a solution on the web [1] but it doesn't work for me :( If
>> I understand correctly, the trick is to load the file as layer and then
>> release it. Here its implementation:
>> import processing
>> import os
>>                                           tempOutput,
>>                                           maskFN,
>>                                           output)
>> try:
>>       # add to the map
>>       tempLay = QgsRasterLayer(tempOutput, "tempLay")
>>         if layer.source() == tempOutput:
>>           # Delete the file
>>       print e
>> I didn't find any other solution for the moment. Any suggestion is
>> really very appreciate!
>> Thanks
>> enrico
>> [1]
>> https://gis.stackexchange.com/questions/93143/can-not-delete-file-after-using-runalg-function
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170427/8fbe61b9/attachment.html>
