[Qgis-developer] release file after processing.runalg
enrico chiaradia
enrico.chiaradia at yahoo.it
Fri Apr 28 08:18:15 PDT 2017
Hi Tom and thank you for your contribution.
It's hard to me to understand your issue but I will study it!
In the meantime, I made some tests again and I can replicate my problem
both using the geoalgorithm directly from the processing framework and
using a similar geoprocessing from SAGA (again from the processing
framework).
In both the cases the result is the same and the input file is locked!!!
I can reproduce it on QGIS 2.14.5-Essen/WIN7 and QGIS 2.18.4/WIN10.
Instead, it seems to work under QGIS 2.14.10-Essen on UBUNTU 16.04. In
this case the "map_to_clip.tif.aux.xml" file is created after the
algorithm terminates.
Can someone confirm this issue?
I upload some test file here:
https://github.com/eachiaradia/doc/tree/master/test_alg
enrico
Il 28/04/2017 16:42, Tom Chadwin ha scritto:
> I had a similar issue (I think). I never solved it myself, but Luca did. The
> issue is here:
> https://github.com/tomchadwin/qgis2web/issues/148
> The commit is here:
> https://github.com/tomchadwin/qgis2web/pull/297
> The code used in current master is here:
> https://github.com/tomchadwin/qgis2web/blob/master/utils.py#L257
> So, this might help you, but it might not.
> Tom
> Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
> View this message in context: http://osgeo-org.1560.x6.nabble.com/release-file-after-processing-runalg-tp5318609p5318754.html
> Sent from the QGIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170428/7e88605c/attachment.html>
