[QGIS-Developer] QgsRasterHistogram Python bindings
Denis Rouzaud
denis.rouzaud at gmail.com
Wed Aug 2 02:55:39 PDT 2017
I'm not getting any crash here.
Do you have any mean to produce a stacktrace?
Denis
Le mar. 1 août 2017 à 12:30, Alexander Bruy <alexander.bruy at gmail.com> a
écrit :
> Just tried this and still got crash
> 2017-08-01 12:08 GMT+03:00 Nyall Dawson <nyall.dawson at gmail.com>:
> > On 1 August 2017 at 17:40, Alexander Bruy <alexander.bruy at gmail.com>
> wrote:
> >> Hi,
> >> while working on Processing algorithms I have found an issue with
> >> QgsRasterHistogram class. According to the documentation, member
> >> histogramVector should not be available in Python [0], but it is present
> >> in the corresponding SIP file. However, any attempt to access this
> member
> >> leads to QGIS crash.
> >> Should we remove histogramVector from Python? Or it should be exposed
> >> and there is a bug/incomplete implementation in bindings?
> > That's odd - there's nothing particularly unusal about
> > HistogramVector. A vector of ints should be accessibly from Python.
> > Why not try removing the typedef use from the sip file and see if that
> > helps? E.g.
> > #ifndef SIP_RUN
> > HistogramVector histogramVector;
> > #else
> > QVector<int> histogramVector;
> > #endif
> > Nyall
> >> [0]
> http://qgis.org/api/classQgsRasterHistogram.html#a9bd23abeb4764f3a6c73975ee96fd4ff
> >> Alexander Bruy
> >> _______________________________________________
> >> QGIS-Developer mailing list
> >> QGIS-Developer at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170802/7b25dba1/attachment.html>
