[QGIS-Developer] Fwd: [Qgis-user] QGIS Input Form for PostGIS
Richard Duivenvoorde
rdmailings at duif.net
Fri Aug 4 00:08:59 PDT 2017
Forwarding this to the dev list, as I think I heard people recently
worked on performance of Postgis?
Regards,
-------- Forwarded Message --------
Subject: [Qgis-user] QGIS Input Form for PostGIS
Date: Thu, 3 Aug 2017 09:47:08 +0000
To: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
Hello,
I have a (rather big) Postgres/PostGIS database that basically looks
like this: https://ibb.co/bK7PKv
I want to use QGIS for editing and inserting data.
I already found these ressources:
https://docs.qgis.org/2.18/en/docs/user_manual/working_with_vector/vector_properties.html#fields-properties
https://docs.qgis.org/2.18/en/docs/user_manual/working_with_vector/attribute_table.html#creating-one-or-many-to-many-relations
https://docs.qgis.org/2.18/en/docs/training_manual/create_vector_data/forms.html
I tried it: I created the relations and built custom forms.
However, when I want to insert or edit something. QGIS becomes really
slow and crashes finally. But before I describe the problems in more
detail I want to read more about it. I find the documentation (linked
above) a bit too little.
So, my question:
Is there any documentation I have missed?
Is there any book (chapter) you can recommend?
Do you know of any example where QGIS is used for entering data into
many related tables in Postgres/PostGIS at once?
I am thankful for any hint or resource.
Jakob
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
