[QGIS-Developer] Load vector layer in Processing
Giovanni Manghi giovanni.manghi at gmail.com
Mon Aug 7 02:04:57 PDT 2017
> I noticed it on master
>> On 2.18 it shows all the files by default, as the normal "add vector
>> layer" dialog, then you have the "files of type" dropdown to select a
>> specific type of vector data source, as the normal "add vector layer"
>> dialog.
> there is only all files and an empty entry
I still see the vector type seelctor in QGIS/master on Windows.
Can't try on Linux now. If in your DE that does not show plase open a
ticket and file
it as a regression.
-- G --
More information about the QGIS-Developer mailing list
