[QGIS-Developer] Travis for plugin test can't install QGIS
Matthias Kuhn matthias at opengis.ch
Mon Aug 21 01:16:13 PDT 2017
Hi Anita,
There was (unfortunately) a lot more to it, like path mangling etc.
However, at the moment I wouldn't spend more time on it, Denis is looking into building regularly updated Docker images for master/3.x releases especially designed for easy travis integration. I'll be looking into integrating these for plugin tests these days. You better wait for this.
Matthias
On 08/20/2017 09:44 PM, Anita Graser wrote:
> On Sun, Aug 20, 2017 at 1:51 PM, Anita Graser <anitagraser at gmx.at
> <mailto:anitagraser at gmx.at>> wrote:
>     or something else that I failed to recognize as potential fix?
> ​QGIS and PostGIS look fine now: ​
> https://travis-ci.org/anitagraser/TimeManager
> but Travis now errors with
> ImportError: No module named sip
> and simple tries like pip install sip didn't work ...
> https://github.com/anitagraser/TimeManager/blob/master/.travis.yml
> Regards,
> Anita
More information about the QGIS-Developer mailing list
