[QGIS-Developer] Auxiliary data storage for labeling, UNDO/REDO - where does it belong to?
Alexandre Neto
senhor.neto at gmail.com
Tue Aug 22 08:03:40 PDT 2017
If I may,
I would prefer to have one global undo/redo stack of buttons for all
project related tasks in QGIS main window (this should include labels,
styles, layers order, layer adding and so on). Even if that means that if
you go back too much, you risk removing some layers from the project, or
other more destructive actions. IMHO, having segmented undo/redo will also
create confusion among the users. Map composer, as a different window is
the exception, and should work separately.
Thanks for the work on auxiliary data storage, that will be great!!
Alexandre Neto
Régis Haubourg <regis.haubourg at gmail.com> escreveu no dia terça, 22/08/2017
às 14:47:
> Hi all,
> one major drawback of QGIS has long been that labeling was considered as
> part of the datasources, which can be true in some cases, but often it more
> belong to a project map object
> We, at Oslandia, working on adding Auxiliary storage capabilities to QGIS,
> which was discussed in several QEP [1] before.
> Now we are close to merge but the work but I would like to discuss some
> ergonomics and design polishing.
> In all GIS tool, custom labeling informations have been stored in project
> file, except in QGIS (which was a brilliant idea to keep it simple !).
> A user will now have two ways of storing labeling data :
> - In the datasource by manually adding the fields and setting the
> corresponding labeling widget. Only advanced users, with grants on the
> datasource do that
> - Using an auxiliary data source sqlite db stored inside the project,
> just directly using the labeling toolbar, even on readonly layers. 90 % of
> the users will use that I think.
> If we consider that a label modification (location, style, rotation ...)
> belongs to a project, then we save it when a user saves the project.
> If we consider it is belonging to the data, we save it with data save
> button.
> Rollback for data edits exists using the edit buffer.
> But Rolling back project modifications exists only partially, in
> composer's edit command list or in dynamic styling panel.
> Our concern is about how to handle and display the undo/redo actions for
> labeling when they are stored inside the project file.
> We thought about 4 ways before concluding that:
> - merge the labeling command in the source layer's edit buffer stack ->
> that won't work if the layer is readonly. If a user chose not to use the
> auxiliary data, then it will work like normal editing.
> - add separate buttons to save auxiliary data by hand (which is the same
> action as saving a project in fact). Tollbars are too cluttered and users
> are already confusing data and project save buttons.
> - Create a global "project" or maybe "mapcanvas" level stack, but I
> suspect users would like to be able to rollback style, composer and
> labeling independently, when undoing some labeling action could also remove
> some layers or important styling things.
> - Finally, we decided to add a separate edit buffer for the auxiliary data
> inside the dynamic styling panel, just below the style/label edit buffer.
> So has anyone any strong opinion here?
> Is there any plan somewhere for a Project Undo/Redo, allowing for instance
> to Cancel a layer deletion ?
> If yes, please share your thoughts so that we store each undo/redo stack
> at the right place, and hopefully with something users will understand
> easily.
> All the best,
> Régis
> [1] https://github.com/qgis/QGIS-Enhancement-Proposals/issues/27
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170822/ba7b4a28/attachment.html>
