[QGIS-Developer] Travis for plugin test can't install QGIS
Matthias Kuhn
matthias at opengis.ch
Thu Aug 24 05:24:44 PDT 2017
Hi Anita,
I got around to doing this now.
For the project here I had to add a bit of additional overhead because
it requires some additional binaries and services compared to a plain
installation
- postgres
- java
So I had to use docker-compose (for postgres) and an extra Docker file
(to install the dependencies).
It's still super-easy - it just could be even a tiny bit simpler, if
these are skipped.
It only requires these files:
https://github.com/opengisch/projectgenerator/tree/master/.docker
And these lines:
https://github.com/opengisch/projectgenerator/blob/2bf4d2acc43da9b0bcedd5f530715d287a6d12d6/.travis.yml#L1-L2
It all depends on the awesome work from Denis who managed to provide
regularly updated builds of the current master branch on dockerhub.
Let me know how it goes for you
Matthias
On 08/21/2017 11:58 AM, Anita Graser wrote:
> On Mon, Aug 21, 2017 at 10:16 AM, Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>> wrote:
> Hi Anita,
> There was (unfortunately) a lot more to it, like path mangling etc.
> However, at the moment I wouldn't spend more time on it, Denis is
> looking into building regularly updated Docker images for master/3.x
> releases especially designed for easy travis integration. I'll be
> looking into integrating these for plugin tests these days. You
> better wait for this
> Thanks a lot! I'll do that.
> Anita
