[QGIS-Developer] zzz-db_manager-5-depend error : qgis master 2.99
Nihcas C
nihcas.c76 at gmail.com
Sun Aug 27 20:13:00 PDT 2017
Hi, I mm compiling QGIS from master in VS 2015 on x64.
I am getting error as :
Error MSB6006 "cmd.exe" exited with code
1. zzz-db_manager-5-depend 7 C:\Program Files (x86)\MSBuild\Microsoft.Cpp\
v4.0\V140\Microsoft.CppCommon.targets
and output followed by :
Build started: Project: version, Configuration: RelWithDebInfo x64
Build started: Project: ui, Configuration: RelWithDebInfo x64
Build started: Project: zzz-db_manager-5-depend, Configuration:
RelWithDebInfo x64
Building Custom Rule C:/QGIS/python/plugins/db_manager/db_plugins/postgis/
plugins/versioning/CMakeLists.txt
CMake does not need to re-run because C:\build3\python\plugins\db_
manager\db_plugins\postgis\plugins\versioning\CMakeFiles\generate.stamp is
up-to-date.
Generating ui_DlgVersioning.py
File "C:\QGIS\scripts\\pyuic-wrapper.py", line 26, in <module> import
qgis.PyQt.uic.pyuic
File "C:\build3\output\python\qgis\__init__.py", line 71, in <module> from
qgis.PyQt import QtCore
File "C:\build3\output\python\qgis\PyQt\QtCore.py", line 1, in <module> from
PyQt5.QtCore import *
ImportError: DLL load failed: The specified procedure could not be found.
C:\Program Files
(x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.CppCommon.targets(171,5):
error MSB6006: "cmd.exe" exited with code 1.
========== Build: 2 succeeded, 1 failed, 10 up-to-date, 0 skipped ==========
I am stuck here. Please help me out.
Thanks
Nihcas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170828/504b1a3c/attachment.html>
