[QGIS-Developer] What to do with QgsTransectSample for 3.0?
Victor Olaya
volayaf at gmail.com
Mon Aug 28 04:32:01 PDT 2017
I would advice to go with 1
It's not likely anyone will use this class, so it's the safest option, IMHO
2017-08-26 15:15 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
> Hi all,
> I've just been doing some cleanups on the analysis lib - see
> https://github.com/qgis/QGIS/pull/5078, and I'm now wondering what we
> should do with the QgsTransectSample class.
> Earlier in the cycle Alex and Victor did a bunch of work exposing a
> lot of the analysis lib functionality via processing. But this class
> is not used anywhere - it's not utilised by the master c++ code, and
> is not exposed via processing either. So we're carrying it around only
> for potential use by 3rd party plugins/scripts.
> BUT:
> - it's unmaintained, and has had no work done (beside compilation
> fixes) in the recent past
> - it's outdated, and has a bunch of antique assumptions (like always
> writing to shapefile outputs)
> - there's 0 unit tests
> - there's almost no documentation on exactly WHAT this class does, and
> how it should be correctly used. And without use in the master
> codebase to model from, I can't see how a 3rd party can be expected to
> utilise this code correctly anyway.
> Options I see are:
> 1. remove it and avoid the issues
> 2. get someone who knows how transect sampling SHOULD work to look
> over the current logic, take up maintenance, add unit tests, and
> expose this functionality via processing
> 3. leave it in it's current form with unknown quality and unexposed
> functionality
> Thoughts? I personally see 3 as not an option, and while 2 would be
> nice, I honestly can't see anyone picking this up.
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
