[QGIS-Developer] Adding a new DataProvider - not found by QgsProviderRegistry
Mark Johnson
mj10777 at googlemail.com
Tue Aug 29 06:28:48 PDT 2017
I would like to create a new RasterDataProvider within the same Library as
the
QgsSpatiaLiteProvider, which is called: QgsRasterLite2Provider.
An extra class has been created, but cannot be found by
the QgsProviderRegistry, reporting 'Invalid data provider rasterlite2'.
I have assumed, that since Grass also has both a Raster and Vector provider
that this would not cause a problem.
Some sort of extra step seems to be needed that I have overlooked.
Mark Johnson, Berlin Germany
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170829/7180be0f/attachment.html>
