[QGIS-Developer] How to build QGIS 2.99 with 3D?
Patrick Dunford
enzedrailmaps at gmail.com
Tue Dec 5 05:12:50 PST 2017
If you use Mint it is based on the LTR version of Ubuntu. Currently this
is Ubuntu 16.04 and so suffers from the same problem of out of date
libraries as people using Ubuntu 16.04 natively get.
In this case you need to use the ubuntugis build of Qgis, however you
may run into problems with the LTR version of Qgis (2.18) when using the
ubuntugis repository as they are updated out of sync with each other.
However using a nightly build shouldn't have issues with ubuntugis.
On 06/12/17 01:06, matteo wrote:
> Hi Alexandre,
> I'm very interested in this issue. I think that the problem is related
> to the missing correct version of Qt 5.9.1 in Ubuntu system (are you on
> a Ubuntu machine?).
> In my machine (Mint 18) the default version of Qt is 5.5.1. Would be
> great to know is there are some plans to update the Qt5 version in the
> default Ubuntu repository.
> Cheers
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
