[QGIS-Developer] PostGIS 3D cube lacks vertical faces
Andreas Neumann a.neumann at carto.net
Sun Dec 10 06:35:39 PST 2017
Hi Anita,
Have you tried changing the "Culling" settings in the 3D rendering
properties of the layer
It might solve your issue. Some systems use clockwise, some
counter-clockwise ordering of vertices describing a face. For that
reason you can change the culling setting per layer.
It is, however, a relatively new enhancement and may not be available in
your build, if it is several days old.
Greetings,
Andreas
On 10.12.2017 15:29, Anita Graser wrote:
> Hi,
> I'm testing the 3D view for PostGIS 3D gemetries. I create a cube using
>    'POLYHEDRALSURFACE Z (
> ((0 0 0, 0 1 0, 1 1 0, 1 0 0, 0 0 0)),
> ((0 0 0, 0 1 0, 0 1 1, 0 0 1, 0 0 0)),
> ((0 0 0, 1 0 0, 1 0 1, 0 0 1, 0 0 0)),
> ((1 1 1, 1 0 1, 0 0 1, 0 1 1, 1 1 1)),
> ((1 1 1, 1 0 1, 1 0 0, 1 1 0, 1 1 1)),
> ((1 1 1, 1 1 0, 0 1 0, 0 1 1, 1 1 1))
> )'::geometry,
> but if I enable the 3D renderer, only the bottom and the top (the two
> horizontal faces) are drawn. The vertical faces are invisible.
> Should I be creating the cube in some other way? Or is this an issue
> with the rendering?
> Regards,
> Anita
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171210/15c1c47a/attachment.html>
More information about the QGIS-Developer mailing list
