[QGIS-Developer] Build problems of master (GDAL related)
Andreas Neumann a.neumann at carto.net
Wed Dec 13 01:26:37 PST 2017
I tried to build latest QGIS master but run into - probably - GDAL issues:
47/4075] Generating qgsversion.h, qgsversion.inc
Files "/home/an/dev/QGIS/build/qgsversion.h.temp" to
"/home/an/dev/QGIS/build/qgsversion.h" are different.
[104/4075] Building CXX object
src/core/CMakeFiles/qgis_core.dir/qgsvectorfilewriter.cpp.o
FAILED: src/core/CMakeFiles/qgis_core.dir/qgsvectorfilewriter.cpp.o
/usr/lib/ccache/c++  -DENABLE_TESTS -DQGISDEBUG=1 -DQT_CONCURRENT_LIB
-DQT_CORE_LIB -DQT_DISABLE_DEPRECATED_BEFORE=0 -DQT_GUI_LIB
-DQT_NETWORK_LIB -DQT_NO_CAST_TO_ASCII -DQT_POSITIONING_LIB
-DQT_PRINTSUPPORT_LIB -DQT_SQL_LIB -DQT_SVG_LIB -DQT_WEBKITWIDGETS_LIB
-DQT_WEBKIT_LIB -DQT_WIDGETS_LIB -DQT_XML_LIB
-DTEST_DATA_DIR=\"/home/an/dev/QGIS/tests/testdata\" -DWITH_BINDINGS
-DWITH_QTWEBKIT -D_HAVE_PTHREAD_ -D_TTY_POSIX_ -Dqgis_core_EXPORTS -I.
-I../src/core -Isrc/core -I../src/core/3d -I../src/core/annotations
-I../src/core/auth -I../src/core/composer -I../src/core/dxf
-I../src/core/effects -I../src/core/expression
-I../src/core/fieldformatter -I../src/core/geometry -I../src/core/geocms
-I../src/core/geocms/geonode -I../src/core/layertree
-I../src/core/layout -I../src/core/locator -I../src/core/metadata
-I../src/core/pal -I../src/core/processing
-I../src/core/processing/models -I../src/core/providers
-I../src/core/providers/memory -I../src/core/raster
-I../src/core/renderer -I../src/core/scalebar -I../src/core/symbology
-I../src/core/gps/qextserialport -isystem /usr/include/x86_64-linux-gnu
-isystem /usr/include/spatialindex -isystem /usr/local/include -isystem
/usr/include/QtCrypto -isystem /usr/include/qt5keychain -isystem
/usr/include/x86_64-linux-gnu/qt5 -isystem
/usr/include/x86_64-linux-gnu/qt5/QtXml -isystem
/usr/include/x86_64-linux-gnu/qt5/QtCore -isystem
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++-64 -isystem
/usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem
/usr/include/x86_64-linux-gnu/qt5/QtGui -isystem
/usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem
/usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -isystem
/usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem
/usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem
/usr/include/x86_64-linux-gnu/qt5/QtWebKit -isystem
/usr/include/x86_64-linux-gnu/qt5/QtWebKitWidgets -isystem
/usr/include/x86_64-linux-gnu/qt5/QtSql -isystem
/usr/include/x86_64-linux-gnu/qt5/QtPositioning -Wall -Wextra
-Wno-long-long -Wformat-security -Wno-strict-aliasing -g -fPIC
-fvisibility=hidden   -fPIC -std=gnu++11 -MD -MT
src/core/CMakeFiles/qgis_core.dir/qgsvectorfilewriter.cpp.o -MF
src/core/CMakeFiles/qgis_core.dir/qgsvectorfilewriter.cpp.o.d -o
src/core/CMakeFiles/qgis_core.dir/qgsvectorfilewriter.cpp.o -c
../src/core/qgsvectorfilewriter.cpp
../src/core/qgsvectorfilewriter.cpp: In static member function ‘static
bool QgsVectorFileWriter::supportsFeatureStyles(const QString&)’:
../src/core/qgsvectorfilewriter.cpp:126:43: error:
‘GDAL_DCAP_FEATURE_STYLES’ was not declared in this scope
    return CSLFetchBoolean( driverMetadata, GDAL_DCAP_FEATURE_STYLES,
false );
../src/core/qgsvectorfilewriter.cpp:126:43: note: suggested alternative:
‘GDAL_DCAP_DEFAULT_FIELDS’
false );
[113/4075] Building CXX object
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposition.cpp.o
ninja: build stopped: subcommand failed.
I use GDAL SVN (latest version): GDAL 2.3.0dev, released 2017/99/99
Any idea what could be done to fix my compile issues?
Thanks a lot,
Andreas
More information about the QGIS-Developer mailing list
