[QGIS-Developer] QGIS 3D: looking below the terrain model
Andreas Neumann a.neumann at carto.net
Wed Dec 13 06:31:10 PST 2017
Being a caver, I have a lot of underground data. Thanks to the support
from Martin I got them to load correctly as 3D polygondata.
However, one issue I have is that the terrain rendering disappears when
I look below the terrain model surface - which isn't so nice for a caver
or geologist. Is this also an issue about culling? Would it be possible
to enable the rendering of the backside of the terrain surface?
The other issue I have is that tilting is somehow locked at the horizon.
I can look down on the terrain and then rotate the whole model until I
look sideway into the model, but than the rotation is blocked. I cannot
rotate any further so that my camera gets below the surface and that I
could move below the surface and look up towards the terrain. I guess
this makes a lot of sense for people who do not need to explore things
below the terrain surface, but for geologists or cavers, it would be
great if this rotation/tilting blocking could be disabled somehow.
Thanks,
Andreas
More information about the QGIS-Developer mailing list
