[QGIS-Developer] Run processing model on selected features only
Paolo Cavallini
cavallini at faunalia.it
Thu Dec 14 00:26:36 PST 2017
Hi Nyall,
Il 13/12/2017 23:20, Nyall Dawson ha scritto:
> (Note that ALL algorithms which use feature source parameters will
> happily accept a vector layer parameter and operate on the all the
> features in that layer... but that's just done to make the modeler as
> flexible as possible).
> I plan on renaming "Feature Source" -> "Vector layer features" in the
> modeler to help clarify this (also "layer field" -> "vector layer
> field"), and I'll add some tooltips too. (also sort that list)
seems a good change; IMHO we have to be carefl here, as this may prove
complicated and confusing to users. I believe more checks and comments
from "normal users" will be useful.
> Another (related) question. I've been thinking model input UI should
> be reworked. My proposal:
> - remove the list of input types
> - change it to a dock with a list of inputs present in the current
> model, with an "add" (and remove) button to add new inputs to the
> model (at which point the input type selection will be asked)
> - add up/down reordering controls for inputs (supported in the backed,
> but in the frontend there's no way to set the ordering. Which is a
> pain for making end-user usable models)
> Thoughts?
+1 from me
thanks!
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
