[QGIS-Developer] Dependencies error: QGIS 2.99 on Debian stretch
Patrick Dunford enzedrailmaps at gmail.com
Thu Dec 14 05:22:04 PST 2017
The package release file for stretch currently lists several
incompatible package versions that are dependencies of mentioned packages.
I assume the build team for some reason did not build all the packages
overnight. Hopefully they will fix this with the next build.
On 15/12/17 00:08, Idan Miara wrote:
> he following packages have unmet dependencies:
>  python-qgis : Depends: python-qgis-common (=
> 1:2.99.0+git20171211+61db97f+14stretch) but it is not going to be
> installed
>                Recommends: liblwgeom-dev but it is not going to be
> installed
>  qgis : Depends: qgis-providers (=
> installed
>         Depends: qgis-common (=
> installed
>  qgis-plugin-grass : Depends: qgis-plugin-grass-common (=
> installed
> E: Unable to correct problems, you have held broken packages.
More information about the QGIS-Developer mailing list
