[QGIS-Developer] The left hand doesn't know what the right hand is doing
    Patrick Dunford
    enzedrailmaps at gmail.com
    Sat Dec 16 11:43:03 PST 2017
61db97f
On 17/12/17 01:57, Denis Rouzaud wrote:
> Hi Patrick,
> May I ask you the version you're using (the commit sha found in about
> dialog)?
> Cheers,
> Denis
> Le sam. 16 déc. 2017 à 08:33, Patrick Dunford <enzedrailmaps at gmail.com
> <mailto:enzedrailmaps at gmail.com>> a écrit :
>     With a recent change in masters the project file format has been
>     broken
>     yet again (it seems) and now instead of recognising EPSG:3857 on
>     project
>     files that are not very old, it comes up as USER:100029
>     Now ordinarily this wouldn't be an issue, just open project properties
>     and change the CRS. Except there is a well documented bug that
>     makes the
>     software crash when you try to do this.
>     As it's not possible in any way for me to fix this latest inability to
>     recognise the CRS from the previous project file from a slightly
>     earlier
>     version of master, maybe it would be helpful to document how we could
>     actually insert the CRS into the project file by hand so it is
>     correct.
>     thanks
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171217/a40b360f/attachment.html>
