[QGIS-Developer] The left hand doesn't know what the right hand is doing
Patrick Dunford
enzedrailmaps at gmail.com
Sun Dec 17 22:38:42 PST 2017
Sorry. I have appreciated since writing this email that you guys could
not have foreseen how the project properties dialog box crashes because
no one else reported that as a bug.
There's a paradox (or tension) here: to get the best testing you have to
be using this software every day to do as many things as possible. That
creates issues when something breaks in a project file, if it's hard to
fix easily.
Every time the CRS changed I changed it back but now it crashes when I
try to do that. The changes in layer styles that don't migrate was small
compared to being unable to set the correct CRS on a project because the
CRS gui crashes.
On 18/12/17 18:47, Nyall Dawson wrote:
> On 16 December 2017 at 22:32, Patrick Dunford <enzedrailmaps at gmail.com> wrote:
>> With a recent change in masters the project file format has been broken yet
>> again (it seems) and now instead of recognising EPSG:3857 on project files
>> that are not very old, it comes up as USER:100029
>> Now ordinarily this wouldn't be an issue, just open project properties and
>> change the CRS. Except there is a well documented bug that makes the
>> software crash when you try to do this.
>> As it's not possible in any way for me to fix this latest inability to
>> recognise the CRS from the previous project file from a slightly earlier
>> version of master, maybe it would be helpful to document how we could
>> actually insert the CRS into the project file by hand so it is correct.
> Patrick,
> Your bug testing is very much appreciated - the way you word your
> email subjects, not so.
> Nyall
