[QGIS-Developer] Support to loading GIS projects from an extended OWC geopackage in the QGIS core
Matthias Kuhn
matthias at opengis.ch
Mon Dec 18 00:47:45 PST 2017
Hi
First, thanks for sharing your thoughts, Joana.
To make sure I understand the approach proposed here. It will preserve
any style information and labeling which can be converted to SLD, but
not other qgis specific ones (which I think is an implication of the
term "standard" which doesn't apply to the qgis project file xml
format)? In explicit having maximum cross-compatibility while
sacrificing some of the advanced QGIS rendering possibilities.
Régis, I remember Even Rouault had some inputs how to create a
spatialite db without all this information (some flag on creation). I
would enjoy seeing the gpkg approach though (and wonder why your message
sounds like accessing it via spatialite is a key requirement).
Cheers
Matthias
On 12/18/2017 09:39 AM, Régis Haubourg wrote:
> Hi again,
> two sidenotes:
> - we called "auxiliary storage" the new QGIS 3 feature. I realize
> everyone uses "Ancillary storage" words. Should we rename that in the
> GUI?
> - we HAD to use SQLITE and not spatialite, even though we wanted to
> use a spatially enabled db. It turned out that init time to create a
> spatialite with current provider was way too long, and having a
> default empty DB storing more than 4Mo of SRS, functions and various
> metadata was not a good idea for QGIS project file. Can anyone give us
> imputs if GPKG, relying on spatialite implementation could suffer from
> the same drawbacks?
> And more largely on pushing hard on OWC standard, I think it is always
> a good idea that OpenSource is the leader on standards.
> The feature could be exposed in "project" menu entry. "Save / Save As
> / Export As OWC" for instance
> 2017-12-18 9:21 GMT+01:00 doublebyte <joana at doublebyte.net
> <mailto:joana at doublebyte.net>>:
> Hi,
> Just to elaborate a bit more some ideas about the geopackage as a
> format to
> support to ancillary storage:
> - From the mere technical point of view, geopackage is very
> convenient for
> storing QGIS projects. This is because we can actually store
> *everything*
> within the geopackage: project information, data, metadata, style
> and other
> data such as the information about labelling.
> - However, in my opinion, the added value of the OWC geopackage
> extension,
> which differentiates it from a common sqlite or spatialite db, is
> the fact
> that it relies on* OGC standards*. This is what enables us to port
> information to other GIS software which is no necessarily QGIS-aware.
> - Our proposal for the OWC geopackage extension is to keep it
> standards-based, which means that we could support use cases such
> as the
> ancilliary storage, if we would use mechanisms such as the tjs
> standard.
> Although the support to queries in the OWC context which Paul
> mentioned is
> still at the level of discussion, standards do evolve and I think
> that we
> (as QGIS community) could also get involved in this evolution,
> whenever we
> are pushing for generic and abstract mechanisms which could be
> reused by the
> whole geopackage community. So to wrap it up, the answer is "yes",
> we could
> support the ancillary storage, but we need to find out exactly how.
> - Another interesting feature which arises from this discussion,
> is the
> ability to support QGIS geopackage extensions in the core. Right
> now, the
> core reader is aware of the "standard" geopackage format (through
> OGR) and
> of the "qgis extension". If we implement it, it would also be
> aware of the
> "owc extension". But what if we could create a more abstract
> reader, which
> would look for extension tables and relate them to a certain "type" of
> plugin? This would allow people to implement reading support to
> different
> "flavours" of geopackages without much effort. I did not made a risk
> anaysis, so I am not sure if there are security (or other) issues
> associated
> to this, but I would love to hear your thoughts about this topic.
> Joana
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> <http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe:
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171218/40f4a238/attachment-0001.html>
