[Qgis-developer] Area calculation issues
Neumann, Andreas
a.neumann at carto.net
Wed Feb 1 00:55:53 PST 2017
Regarding field calculator:
I wonder what the difference between $area and area($geometry) is?
They deliver different results - sometimes quite close, but sometimes
with a hug difference.
I have to add, that the data contains circular arcs.
Tested with 2.18.x. OTF off.
Nyall - I remember that you dived into this issue in one of the past bug
fixing efforts? Can you explain it? I can deliver a small dataset
demonstrating the issue.
Another user reported me that area calculation results are different
depending on OTF is on or off (I have to ask which QGIS version, he did
not tell). All data sets in the projects use a meter based system. The
data set of the assumedly wrong area calculations are in the same
coordinate system as the project.
Thanks,
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170201/bb519d06/attachment-0001.html>
